OS-T: 1385 Heat Transfer Analysis on Piston Rings with GAP Elements
Piston rings fit on the outer surface of a piston in an engine. They support heat transfer from the piston to the cylinder wall. This tutorial demonstrates running a heat transfer analysis on a set of piston rings.
Launch HyperMesh and Set the OptiStruct User Profile
Import the Model
Set Up the Model
Create PGAP and PGAPHT Property
Create PGAP and PGAPHT property before creating gap elements.
