Bulk Data Entry Defines material properties for nonlinear creep
materials.
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
MATVP |
MID |
CTYPE |
A |
n |
m |
(1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
(9) |
(10) |
MATVP |
2 |
STRAIN |
3.28e-11 |
3.15 |
-0.2 |
Field |
Contents |
SI Unit Example |
MID |
Unique material identification number.
No default (Integer > 0)
CTYPE |
Specifies the creep material model
type.
- STRAIN (Default)
- Strain hardening form
- TIMEC
- Time hardening form using creep time
- TIMET
- Time hardening form using total time
A |
Material parameter. Default = blank
(Real > 0.0)
n |
(Real > 0.0)
m |
(-1.0 ≤ Real ≤ 0.0)
- CHEXA,
CTETRA, CPENTA, CPYRA elements
are supported.
- Specifying a MAT1 and a
MATVP with the same MID allows modeling creep
material. Specifying a MAT1, a MATS1 and a
MATVP with the same MID can model a creep material
with plasticity.
- You can choose explicit or implicit time
integration for creep materials by using the TINT field of the
VISCO card.
- The STRAIN hardening formulation
is:(1)
The TIME hardening formulation is:
(2)
Where,
- Equivalent creep strain rate
- Equivalent deviatoric stress
- Total time
- The units for
is
Where,
- Force
- Length
- Time
You might consider switching to another set of units if the value of
is too small.
- A VISCO Subcase Entry is
mandatory to conduct creep material analysis in a particular subcase.
- MATVE is supported for small
displacement and large displacement nonlinear analysis.
