MATX44
Bulk Data Entry Defines additional material properties for Cowper-Symonds elastic-plastic material for geometric nonlinear analysis.
MATX44 | MID | A | B | N | ICH | SIGMAX | C | P | |
ICC | FSMOOTH | FCUT | EPSMAX | EPST1 | EPST2 |
MAT1 | 144 | 0.11 | 0.11 | 9.92E-07 | |||||
MATX44 | 144 |
MID | Material ID of the
associated MAT1. No default (Integer > 0) |
A | Plasticity yield
stress. (Real > 0) |
B | Plasticity hardening
parameter. (Real ≥ 0) |
N | Plasticity hardening
exponent. Default = 1.0 (Real) |
ICH | Hardening coefficient.
(Real ≥ 0) |
SIGMAX | Maximum plastic stress
max0. Default = 1030 (Real > 0) |
C | Strain rate
coefficient. Default = 0.0 (Real) |
P | Strain rate
ICC | Strain rate dependency
of
max flag.
5
FSMOOTH | Strain rate smoothing
flag.
FCUT | Cutoff frequency for
strain rate filtering. Default = 1030 (Real ≥ 0) |
EPSMAX | Failure plastic
strain. Default = 1030 (Real > 0) |
EPST1 | Tensile rupture strain
1. Default = 1030 (Real > 0) |
EPST2 | Tensile rupture strain
2. Default = 2.0 * 1030 (Real > 0) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX44 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS = EXPDYN. It is ignored for all other subcases.
- The Cowper-Symonds models an
elastic-plastic material, only for solids and shells. The basic principle is the
same as the standard Johnson-Cook model; the only difference between the two lies in
the expression for strain rate effect on flow stress.
(1) with p being plastic strain, and being the strain rate.
- Hardening is defined by
ICH.
Figure 1. - ICC controls the strain
rate effect.
Figure 2. - No strain rate effects are considered in rod elements.
- Strain rate filtering is used to smooth strain rates. The input FCUT is available only for shell and solid elements.
- When the plastic strain reaches EPSMAX, the element is deleted.
If the first principal strain
1 reaches t1 =
EPST1, the stress
is reduced by:
(2) with t2 = EPST2.
- If the first principal strain 1 reaches t2 = EPST2, the stress is reduced to 0 (but the element is not deleted).
- If the first principal strain 1 reaches f = EPSF, the element is deleted.
- This card is represented as an extension to a MAT1 material in HyperMesh.
