MATX82
Bulk Data Entry Defines additional material properties for Ogden material for geometric nonlinear analysis. This material is used to model rubber, polymers, and elastomers.
MATX82 | MID | ||||||||
LAW | MU1 | ALFA1 | D1 | MU2 | ALFA2 | D2 | |||
MU3 | ALFA3 | D3 | MU4 | ALFA4 | D4 | ||||
etc |
MAT1 | 102 | 10.0 | 0.495 | 6.0E-10 | |||||
MATX82 | 102 | ||||||||
LAW | 0.10 | 2.0 | -0.010 | -2.0 |
MID | Material ID of the associated
MAT1. 1 No default (Integer > 0) |
LAW | Indicates that material parameters MUi, ALFAi, and Di follow. | |
MUi | Parameter
(Real) |
ALFAi | Parameter
(Real) |
Di | Parameter
Di (Real) |
- The material identification number must be that of an existing MAT1 Bulk Data Entry. Only one MATXi material extension can be associated with a particular MAT1.
- MATX82 is only applied in geometric nonlinear analysis subcases which are defined by ANALYSIS=EXPDYN. It is ignored for all other subcases.
- NU is defined on the corresponding MAT1. For material without Poisson effect, a small NU (for example, =1.E-10) should be defined.
- The
strain energy density
is computed using:
(1) with being the ith principal stretch, J = 1 * 2 * 3 being the relative volume and .
- The
Bulk Modulus K is:If NU = 0,
(2) If NU ≠ 0, then the value is modified to respect.(3) If NU = 0 and = 0, then = 0.475.
- The
ground shear modulus is:
(4) - This card is represented as a material in HyperMesh.
