Bulk Data Entry Defines the handling of initial loading
conditions on pretension sections that have been defined, but not yet explicitly loaded via
PRETENSION command.
Parameter |
Values |
Description |
INILOAD |
<ZEROF
\, ZEROA> |
- ZEROF (Default)
- In a pre-tensioning subcase, for any pretension section
without pretension load, zero force will be applied.
This is equivalent to setting zero
PTFORCE.
- ZEROA
- Zero relative deformation is enforced on the pretension
section defined above. This is equivalent to setting
zero PTADJST.
