RLOAD1
Bulk Data Entry Defines a frequency-dependent dynamic load of the form: for use in frequency response problems.
RLOAD1 (Form 1) can be used when the frequency-dependent dynamic load input is available in real/imaginary number format.
RLOAD1 | SID | EXCITEID | DELAY | DPHASE | TC | TD | TYPE |
RLOAD1 | 5 | 3 | 1 |
SID | Set identification number. Must be
unique for all RLOAD1 and RLOAD2 entries. No default (Integer > 0) |
EXCITEID | Identification number of the
DAREA, SPCD, FORCEx,
MOMENTx, PLOADx, RFORCE,
ACCEL, ACCEL1, ACCEL2 or
GRAV entry set that defines
A. No default (Integer > 0) |
DELAY | Defines time delay
. If it is a non-zero integer, it represents the
identification number of a DELAY Bulk Data
Entry that defines
. If it is Real, then it directly defines the value of
that will be used for all degrees-of-freedom that are excited
by this dynamic load entry. Default = 0 (Integer ≥ 0, or Real) |
DPHASE | Defines phase
in degrees. If it is a non-zero integer, it represents the
identification number of a DPHASE Bulk Data
Entry that defines
TC | Set identification number of the TABLED1, TABLED2, TABLED3, TABLED4 or TABLEG
entry that gives
. 2 Default = 0 if TD is non-zero (Integer ≥ 0) |
TD | Set identification number of the
TABLED1, TABLED2,
entry that gives
. 2 Default = 0 if TC is non-zero (Integer ≥ 0) |
TYPE | Identifies the type of the dynamic
excitation. Default = 0 4 |
- Dynamic load sets must be selected in the I/O Options or Subcase Information sections with the command DLOAD=SID.
- If any DELAY, DPHASE, TC, or TD fields are blank or zero, the corresponding , , , or will be zero. Either TC or TD may be blank or zero, but not both.
- RLOAD1 loads may be combined with RLOAD2 loads only by specification on a DLOAD entry. This means that the SID on a RLOAD1 entry must not be the same as that on a RLOAD2 entry.
- Valid
entries for the TYPE field are
listed alongside a description of the dynamic
excitation which they invoke.
Type Description 0, L, LO, LOA, LOAD Applied load; EXCITEID references DAREA data. 1, D, DI, DIS, DISP Enforced displacement; EXCITEID references SPCD data. 2, V, VE, VEL, VELO Enforced velocity; EXCITEID references SPCD data. 3, A, AC, ACC, ACCE Enforced acceleration; EXCITEID references SPCD data. - When EXCITEID refers to an SPCD entry, the modal space will be augmented with displacement vector(s) from linear static analysis with unit prescribed displacement at each of the SPCD degrees-of-freedom.
- All static structural loads can be referenced by EXCITEID by referring to the SID on the structural load. The structural loads are FORCE, FORCE1, FORCE2, MOMENT, MOMENT1, MOMENT2, PLOAD, PLOAD1, PLOAD2, PLOAD4, RFORCE, ACCEL, ACCEL1, ACCEL2 and GRAV. EXCITEID cannot reference the LOAD and LOADADD Bulk Data Entries.
- This card is represented as a load collector in HyperMesh.
