RVDOF
Bulk Data Entry Defines the degrees of freedom where the residual vectors are to be calculated.
RVDOF G1 C1 G2 C2 G3 C3 G4 C4
RVDOF 564 4 765 4561
Gi Grid or scalar point identification numbers.
No default (Integer > 0)
Ci Component numbers.
Integer zero or blank for scalar points, or up to 6 unique digits (0 < integer ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.
