SEQSET
Bulk Data Entry Defines the generalized degrees-of-freedom of the superelement for use in One-Step Superelement Analysis.
SEQSET SEID G1 C1 G2 C2 G3 C3
SEQSET 11 23 123456 8 1 5 3
SEID Superelement identification number
No default (Integer ≥ 0)
Gi Grid or Scalar Point identification numbers (should be an external point)
Default = Blank (Integer > 0)
Ci Component numbers
Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.
  1. Degrees-of-freedom on SEQSET entry should not be used on any other Superelement.
