OS-E: 0330 Sine Sweep Fatigue Analysis
Sine sweep fatigue analysis of a simple bracket is done to study the fatigue life of the structure under sinusoidal loading using OptiStruct.
Figure 1. FE Model with Loadcases and Loadstep
Model Description
Frequency Response Stress results from the Frequency Response Analysis are used to calculate the frequency-dependent stress range, which are subsequently used to calculate Fatigue damage based on sweep rate. Here the stress-life (SN) approach is used for calculating the fatigue life of the component.
- Bracket
- First order Tetra elements
- Skin Surface Near the Fillet Region
- First order Tria elements
- MAT1 with MATFAT
- Young's Modulus
- 2.1 x 105 N/mm2
- Poisson's Ratio
- 0.3
- Density
- 7.9 x 10-9 ton/mm3
- Shear Modulus
- 0.02 N/mm2
- MATFAT
- Yield Strength
- 180 MPa
- Ultimate Tensile Strength
- 340 MPa
- Fatigue Strength Coefficient
- 936
- First Fatigue Strength Exponent
- -0.161907
- Limit of Endurance
- 1 x 1030
- Fatigue Limit
- 1
Figure 2. All the Fatigue Cards used for this Analysis
Results
Figure 3. Fatigue Damage Results
Figure 4. Fatigue Life Results
Model Files
The model files used in this example include:
<install_directory>/hwsolvers/demos/optistruct/examples/Analyse_Fatigue_Sinus_v4.fem
