/BOX/RECTA
Block Format Keyword Describes a rectangle box for entities selection.
/BOX/RECTA/box_ID/unit_ID | |||||||||
box_title |
box_ID | Box identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
box_title | Box title (Character, maximum 100 characters) |
Type is RECTA
N1 | N2 | Iskew | |||||||
Xp1 | Yp1 | Zp1 | |||||||
Xp2 | Yp2 | Zp2 |
N1 | Node identifier (Integer, maximum 10 digits) |
N2 | Node identifier (Integer, maximum 10 digits) |
Iskew | Fixed skew identifier (Integer, maximum 10 digits) |
Xp1 | X coordinate of point
P1 (Real) |
Yp1Y | Y coordinate of point
P1 (Real) |
Zp1 | Z coordinate of point
P1 (Real) |
Xp2 | X coordinate of point
P2 (Real) |
Yp2 | Y coordinate of point
P2 (Real) |
Zp2 | Z coordinate of point
P2 (Real) |
- A box (RECTA) defined above is used for:
