Processing math: 100%
RD-E: 2000 Ice Cube
Ice cube dropping on two sliding channels.
rad_ex_20_cube
The subject in this example demonstrates the falling and sliding of an ice cube on to sloped beams using an explicit transient dynamic analysis for deformable, free-flying objects. The impact and rebound are modeled using penalty contact algorithms.
The Contact between the ice cube, the beams, and the cup are modeled using different penalty contact interfaces (/INTER/TYPE7, /INTER/TYPE24 and /INTER/TYPE25). The ice cube and the beams are modeled using hexahedron elements. The cup is modeled with standard shell elements.
Options and Keywords Used
  • Boundary conditions on node groups for translational and rotational motion (/BCS):
    • The ice cube nodes are constrained in the Y translation.
    • The bottom nodes of the beams are constrained in all directions.
    • The cup is constrained in all directions
  • Gravity (/GRAV):
    • A gravity load (g = 9.81 m/s2) in the Z-direction is applied on the ice cube’s nodes
  • Interfaces: Three different node to surface penalty contact interfaces are compared with each other. For each model, the ice cube is the slave and the master is the beams and cup.
    • /INTER/TYPE7 interface uses the penalty method with an initial gap of 0.1. Ice cube nodes are the slave and the master surface is defined using the upper surface of the beams and the cup. To replicate surface to surface contact, a second TYPE7 contact is created with the ice cube as master surface and the beams and cup as slave nodes. The interface stiffness is the minimum value of the master and slave stiffness (Istf = 4). The TYPE7 interface is a general impact interface with a nonlinear stiffness. In case of high impact speed or contacts with a small gap, the time step can be reduced because the contact stiffness will increase if the slave node penetrates closer to the master surface.
    • /INTER/TYPE24 interface uses the penalty method without any contact gap between the solid elements. A surface to surface contact is defined where the ice cube is defined as a slave surface and the master surface is defined using the upper surface of the beams and the cup. The interface stiffness is the minimum value of the master and slave stiffness (Istf = 4). The TYPE24 interface is a general nodes-to-surface contact interface using the penalty method with a constant interface stiffness which means there is no reduction in time step due to slave node penetration. Three different input types can be used: single surface, surface to surface, or nodes to surface. This contact is typically used for drop test simulations.
    • /INTER/TYPE25 is very similar to TYPE24 in its definition and algorithm. However, it is being developed for crash impact simulations and; therefore, has a few different options and algorithms.
  • /PROP/TYPE1 (SHELL)
  • /PROP/TYPE14 (SOLID)
Input Files
The input file used in this example includes:
  • <install_directory>/hwsolvers/demos/radioss/examples/20_Cube/
Model Description
This problem provides a comparison of different contact interfaces that allow sliding contact between an ice cube and steel beams.
The cube is submitted to gravity and slides on declined fixed beams. Finally, it is collected in a cup. The width of the cube is 30 mm and the dimensions of the beams are 40 x 30 x 500 mm.
The ice cube is modeled as a simple elasto-plastic material using /MAT/LAW2, with the following characteristics:
Initial density
9.16e-10 Mgmm3
Young's modulus
8996 [MPa]
Poisson's ratio
0.3
Yield Stress, SIGY
1.0 [MPa]
Hardening parameter, b
4.0 [MPa]
Hardening exponent, n
0.5
The material used for the beams and the cup is steel and follows an isotropic elasto-plastic material (/MAT/LAW2) with the Johnson-Cook plasticity model, having the following characteristics:
Initial density
7.8e-09 Mgmm3
Young's modulus
210000 [MPa]
Poisson's ratio
0.3
Yield stress, SIGY
200 [MPa]
400 [MPa]
0.5
Units: mm, s, Mg, N, MPa
Results
Figure 2 shows the trajectory of the ice cube for the three different contact interfaces, which was created using the Trace component option in HyperView. The impact of the cube on the first beam is very similar for all three contact interfaces. As the minor differences accumulate, the motion becomes different after the impact with the second beam.
rad_ex_fig_20-3
Figure 2. Trajectory of the Ice Cube using Interface TYPE7, TYPE24 and TYPE25
Figure 3 shows a comparison of the total reaction forces for the three interfaces. The differences in the results are to be expected since all interfaces have different formulations. Those differences accumulate resulting in different motion toward the end of the simulation.
rad_ex_fig_20-4
Figure 3. Comparison of the Reaction Forces of the Ice Cube on the Beams
