/EBCS/FLUXOUT
Block Format Keyword Define the flux output elementary boundary condition used with /MAT/LAW151.
/EBCS/FLUXOUT/ebcs_ID
ebcs_title
surf_ID
ebcs_ID Elementary boundary condition identifier.
(Integer, maximum 10 digits)
ebcs_title Elementary boundary condition title.
surf_ID Surface identifier.
(Integer)
  1. The FLUXOUT boundary condition is compatible with /MAT/LAW151.
  2. FLUXOUT imposes a zero normal derivative of the fluxes on the elements of the input surface: mass, momentum and energy fluxes.
  3. This will provide a continuity of the numerical solution if the outgoing flow is supersonic. However, this may lead to wave reflection with subsonic flows.
