/FAIL/TAB1
Block Format Keyword This advanced failure model allows the failure strain to be defined as a function of: stress triaxiality, strain rate, Lode angle, element size, temperature, and instability strain. Damage is accumulated based on user-defined functions.
/FAIL/TAB1/mat_ID/unit_ID
Ifail_sh Ifail_so     P_thickfail P_thinfail   Ixfem
Card 2 - Damage accumulation parameters
Dcrit Dp n Dadv fct_IDd
Card 3 - Failure strain table dependent on stress triaxiality and Lode angle parameter
table1_ID Xscale1 Xscale2 table2_ID Xscale3 Xscale4
Card 4 - Element size scale function
fct_IDel Fscaleel El_ref inst_start Fad_exp Ch_i_f
Card 5 - Temperature scale function
fct_IDT FscaleT
Card 6 - Optional line
fail_ID
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
Ifail_sh Shell failure flag.
If Ixfem =0: failure - element deleted. 1
If Ixfem =1: failure - element cracked. 2
(Integer)
= 1
Shell is deleted/cracked, if the damage criterion is satisfied in one integration point or layer.
= 2
Shell is deleted/cracked, if the damage criterion is satisfied in all shell layers. For a single layer shell, the stress tensor is set to zero.
= 3
Shell is deleted/cracked, if the damage criterion is satisfied in all layers. Stress tensor is not modified in broken layers until the complete element is ruptured.
Ifail_so Solid failure flag.
= 1
Solid is deleted, if the damage criterion is satisfied in one integration point.
= 2
Deviatoric stress components are set to zero for the integration points where criteria is satisfied.
(Integer)
Ixfem XFEM flag (for /SHELL and /SH_SANDW properties only).
= 0 (Default)
Without XFEM.
= 1
XFEM formulation. 2
(Integer)
P_thickfail Percentage of through thickness integration points that must fail before the element is deleted. (shells only). Only used when Ifail_sh=2 or 3. 2 6 7
(Real)
P_thinfail Ratio of thickness reduction before failure (shells only and only active for Ifail_sh > 1).
(Real)
Dcrit Critical accumulated damage value (failure criteria).
Default = 0.999 (Real)
Dp Damage accumulation parameter.
Default = 1.0 (Real)
n Damage accumulation parameter.
Dadv Criterion for the crack advancement (Only active if Ixfem=1).
(Real, between 0 and 1)
Default = 0 means Dadv = Dcrit 4
fct_IDd Damage function identifier. 5
Default = 0 (Integer)
table1_ID Failure strain table identifier. 3
(Integer)
Xscale1 Scale factor for the first variable of table1 (failure strain).
[Pa]
Xscale2 Scale factor for the second variable table1 (strain rate).
[1s]
table2_ID Instability strain table identifier. 9
(Integer)
Xscale3 Scale factor for the first variable of table2 (strain rate).
Default = 1.0
Xscale4 Scale factor for the second variable of table2 (instability strain).
Default = 1.0
fct_IDel Element size factor function identifier.
(Integer)
Fscaleel Element size function scale factor.
El_ref Reference element size.
[m]
inst_start Instability strain (Only used if table2_ID is not defined).
Default = Dn (Real)
Fad_exp Fading exponent. 9
> 0 (Default)
Fading exponent. (Real)
< 0
Fading exponent relative to element size function identifier. (Integer)
Ch_i_f Choice of instability or fracture regularization flag.
= 1 (Default)
Element length regularization affects the fracture curve.
= 2
Element length regularization affects the instability table.
= 3
Element length regularization affects both fracture curve and instability table.
fct_IDT Temperature factor function identifier.
(Integer)
FscaleT Temperature function scale factor.
fail_ID (Optional) Failure criteria identifier. 10
Example (Shell)
In this example diffuse necking are considered using instability strain options (table2_ID and Fad_exp).
#RADIOSS STARTER
/UNIT/1
unit for mat
#              MUNIT               LUNIT               TUNIT
                  kg                  mm                  ms
#-  1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Steel
#              RHO_I
              7.9E-6                   0
#                  E                  Nu     Iflag
                 210                  .3         0
#                  a                   b                   n           EPS_p_max            SIG_max0
                 .05                 .52                  .1                   0                   0
#                  c           EPS_DOT_0       ICC   Fsmooth               F_cut               Chard
                .022                .001         0         1                   1                   0
#                  m              T_melt              rhoC_p                 T_r
                1.03                1796                3.91                 300
/FAIL/TAB1/1/1
# failure for shell
# Ifail_sh  Ifail_so                             P_THICKFAIL          P_THINFAIL              I_Xfem
         2         1                                       1                   0                   0
##CARD2  - Damage accumulation parameters
#              DCRIT                   D                   N                Dadv   fct_IDd
                   1                  .1                   1                   0         0
#CARD3  - Failure strain functions for each defined strain rate  (Nrate lines, at least one)
#Table1_ID             Xscale1             Xscale2 Table2_ID             Xscale3             Xscale4
      4711                   1                   1      4712                   1                   1
#CARD4 - Element size scale function
#FCT_ID_EL           FSCALE_EL              EI_REF          INST_START             FAD_EXP    Ch_i_f
        21                   1                   1                  0                   10         0
#CARD5 - Temperature scale function
# FCT_ID_T            FSCALE_T
        22                   1
#CARD6 - Function identifier (optional card)
#  Fail_Id
         1
#-  3. FUNCTIONS:
/TABLE/1/4711
failure plastic-strain vs triaxiality for material failure
         1
#        Triaxiality      Failure_Strain
                 -1.                0.50
                  1.                0.50
/TABLE/1/4712
failure plastic-strain vs triaxiality for diffuse necking
         1
                 -1.                0.30
                  1.                0.30
/FUNCT/21
Element length regularisation
#                  X                   Y
# relative ele. size        scale factor
                  .1                   1
                 .25                   1
/FUNCT/22
#                  X                   Y
                   0                 1.0
                1000                 1.0
#enddata
/END
Example (Solid)
In this example triaxiality and Lode angle are considered.
#RADIOSS STARTER
/UNIT/1
unit for mat
#              MUNIT               LUNIT               TUNIT
                  kg                  mm                  ms
#-  1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Steel
#              RHO_I
              7.9E-6                   0
#                  E                  Nu     Iflag
                 210                  .3         0
                 .05                 .52                  .1                   0                   0
                .022                .001         0         1                   1                   0
                1.03                1796                3.91                 300
/FAIL/TAB1/1/1
         1         1                                       1                   0                   0
                   1                   1                   1                   0         0
      4711                   1                   1         0                   0                   0
        21                   1                   1                   0                   0         0
# FCT_ID_T            FSCALE_T
        22                   1
#  Fail_Id
         1
#-  3. FUNCTIONS:
/TABLE/1/4711
curve_list Failure Function vs. strain rates vs Lode angle
#DIMENSION
         3
#   FCT_ID                   strain_rate          Lode_angle
      3000                          1E-4                  -1                                       0
      3001                          1E-4                   0                                       0
      3002                          1E-4                   1                                       0
      3003                             1                  -1                                       0
      3004                             1                   0                                       0
      3005                             1                   1                                       0
/FUNCT/3000
fail strain vs triaxiality
#        triaxiality         fail strain
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/3001
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/3002
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/3003
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/3004
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/3005
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/21
#                  X                   Y
                   0                   1
                  10                   1
/FUNCT/22
#                  X                   Y
                   0                   1
                1000                   1
#enddata
/END
  1. Using Ixfem=0, failure leads to element or layer deletion. In this case, if Ifail_sh=1, then P_thickfail has to be set to zero for proper working failure criteria.
  2. Using Ixfem=1 (XFEM formulation), failure leads to element crack:
    XFEM formulation is only compatible with Belytchko (Ishell=1 or 2), Ishell=3 or 4 and QEPH (Ishell=24) shell elements.
    Two XFEM options are available: mono-layer and multi-layer. The XFEM option depends on the property type associated to the failure criterion applied to the material identifier:
    1. If /PROP/SHELL (TYPE1) is used, then mono-layer XFEM will be applied.
      In this case, the whole element thickness is considered as a single layer. The failure criterion is calculated in each integration point but only one single crack can appear in this element. This approach is compatible with all shell flag options (Ifail_sh=1, 2 or 3), as well as P_Thickfail values. The crack direction is determined by the principal constraints in the last failed integration point.
    2. If /PROP/SH_SANDW (TYPE11) is used, then multi-layer XFEM will be applied.
      In this case, each integration point over thickness is considered as a distinct layer. The failure criterion is calculated separately, and the crack direction may be different for each layer. Crack direction in each layer will independently propagate from one element to another. Multi-layer XFEM is not compatible with Ifail_sh=1 and P_thickfail>0. Their values will be automatically set to Ifail_sh=2 and P_thickfail=0.
    Warning: Mono-layer and multi-layer XFEM formulations cannot be mixed in the same model, yet. The choice between them must be made for the whole model.
  3. The plastic failure strain is defined as:(1)
    εf=Xscale1f(σ,˙ε,ξ)factorelfactorT
    Where,
    f(σ,˙ε,ξ)
    Described in table1_ID and is calculated by interpolating between the failure strain versus stress triaxiality functions for strain rate ˙ε and Lode angle ξ .
    σ=σmσVM
    Stress triaxiality
    σm
    Hydrostatic stress
    σVM
    von Mises stress
    The first function from table1_ID is used for strain rate values from 0 to its corresponding strain rate. For strain rates above the last defined function, the failure strain value is extrapolated using the last two curves and their corresponding strain rates.
    It is possible to consider element size in material failure by function fct_IDel to scale the failure strain depending on the normalized element size with Ch_i_f=1 or 3.(2)
    factorel=Fscaleelfel(SizeelEl_ref)
    Where, fel(SizeelEl_ref) is the function of fct_IDel.
    Temperature dependency can be considered in material failure by defining a function to scale the failure strain depending on the normalized temperature:(3)
    factorT=FscaleTfT(T)
    Here, fT(T) is defined using fct_IDT and Temperature T is computed as:(4)
    T=TTiniTmeltTini
    It is recommended to use /HEAT/MAT to define the thermal parameter for material laws (which support thermo-plasticity).
  4. Two different failures (rupture or crack) are introduced in this failure model. The failure criteria is calculated as:
    Element rupture (Ixfem=0):
    • Element rupture (deleted), if (5)
      ΔD>Dcrit
      Dcrit
      The only rupture criterion used when Ixfem=0.
    Element crack (Ixfem=1):
    • Element cracked, if:(6)
      ΔD>Dcrit
      in case no failed neighbors for this element. Dcrit is used for new crack initialization.(7)
      ΔD>Dadv
      in case there is failed neighbors for this element, Dadv is used for crack advancement.
      Element is deleted, if a second crack arrives to the same element.
    Note: Dadv should always be less than Dcrit ( Dadv < Dcrit ). If not, then Dadv is set to Dcrit crit ( Dadv = Dcrit ).
  5. Damage accumulation is computed in Radioss one of two different ways:
    • With parameter input if fct_IDd = 0:(8)
      ΔD=ΔεpεfnDp(11n)
      Where,
      Δεp
      Change in plastic strain of the integration point
      εf
      Plastic failure strain
      Dp and n
      Damage parameters
    • With curve input if fct_IDd0:(9)
      ΔD=Δεpεffd
      Where,
      fd
      Damage scale factor as a function of plastic strain defined in fct_IDd.
      Δεp
      Plastic strain increment.
      fd
      Function of fct_IDd
  6. P_thickfail is only compatible with shell elements (except, shells with /PROP/TYPE11 (SH_SANDW)) and is only used when Ifail_sh=2 or Ifail_sh=3. With Ixfem=1, P_thickfail is only compatible with mono-layer XFEM formulation. 1
  7. When P_thickfail is used, the shell complete rupture occurs when the thickness of broken layers is greater than the ratio of shell total thickness. Any P_thickfail value defined in the shell properties is ignored and the value entered in this failure model is used instead.
    Only adjacent layers that fail consecutively are accounted for the thickness sum (usually from one of external skin to the mid-surface).
  8. The first variable of table1_ID is the plastic failure strain versus stress triaxialit function, the second variable is strain rate and the third is the Lode angle parameter ξ (for solids).
    For shell, only 2D tables are available (no dependency of Lode angle).
  9. Instability (diffuse necking):
    • Only available for shells
    • The fading exponent describes the softening behvior and starts of instability (diffuse necking). The recommended value of Fad_exp is 5 to 10.
      If Fad_exp < 0 and Ch_i_f=2 or 3, then the absolute value of the fading exponent is a function identifier fct_IDel which defines the fading exponent as a function of element length.
    • The start of instability can be described as a function or constant value:
      • table2_ID is a function of instability strain vs. triaxiality where the instability strain defines when diffuse necking starts. Strain rate dependency for diffuse necking could be considered as well using dimension=2 in /TABLE.
      • If table2_ID is not defined, then inst_start is used as constant flat line for instability starting value over the triaxiality.
      • If table2_ID is not defined, then inst_start is used as constant flat line for instability starting value over the triaxiality, where the default value is Dp.
    • The diffuse necking softening is based according to this equation:(10)
      σreduced=σ(1(Dinstabilityinst_start1inst_start)Fad_exp)
      Where, Dinstability=Δεpεf with εf being the diffuse necking strain.
      Currently diffuse necking (material instability) in /FAIL/TAB1 could be used with material laws greater than 28.
  10. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in the .sta file with /STATE/BRICK/FAIL option).
