/MAT/LAW94 (YEOH)
Block Format Keyword This law describes the YEOH material model, which can be used to model incompressible hyperelastic behavior. This law is only compatible with solid elements.
/MAT/LAW94/mat_ID/unit_ID or /MAT/YEOH/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
ρi | |||||||||
Blank | |||||||||
C10 | C20 | C30 | |||||||
D1 | D2 | D3 |
mat_ID | Material identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
mat_title | Material title (Character, maximum 100 characters) |
ρi | Initial density (Real) |
[kgm3] |
C10 | Deviatoric material parameter 1 Default = 0.0 (Real) |
C20 | Deviatoric material parameter 2 Default = 0.0 (Real) |
C30 | Deviatoric material parameter 3 Default = 0.0 (Real) |
D1 | Volumetric material parameter 1, for bulk modulus computation. K=2D1 Default = 0.0 (Real) |
D2 | Volumetric material parameter 2 Default = 0.0 (Real) |
D3 | Volumetric material parameter 3 Default = 0.0 (Real) |
Example (Plastic)
#RADIOSS STARTER
/UNIT/1
unit for mat
Mg mm s
#- 2. MATERIALS:
/MAT/LAW94/1/1
plastic
# RHO_I
1.19E-9
#Blank
# C10 C20 C30
1.3169 0.02758 0.003686
# D1 D2 D3
7.26e-3
#ENDDATA
- The YEOH energy
density.
(1) W=3∑i=1[Ci0(ˉI1−3)i+1Di(J−1)2i]Where,(2) ˉI1=ˉλ21+ˉλ22+ˉλ23and(3) ˉλi=J−13λiThe Cauchy stress is computed as:(4) σi=λiJ∂W∂λi - The initial shear
modulus and the bulk modulus are computed
as:
(5) G=2⋅C10and(6) K=2D1 - If D1= 0, an incompressible material is considered.
- This material has similar compatibilities as LAW42, except it is for Hexa elements only. Verifications for tetrahedral elements is ongoing.
- This material is based on Yeoh, O. H., 1993, "Some forms of the strain energy function for rubber", Rubber Chemistry and Technology, Volume 66, Issue 5, November 1993, Pages 754-771.
