/SURF/DSURF
Block Format Keyword Describes the surface definition. Has the same behavior as /SURF/SURF; except when a negative ID is used.
Enter selected items numbers (any number may be input, 10 per format).
/SURF/DSURF/surf_ID/unit_ID
surf_title
item_ID1 item_ID2 item_ID3 item_ID4 item_ID5 item_ID6 item_ID7 item_ID8 item_ID9 item_ID10
surf_ID Surface identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
surf_title Surface title
item_IDi List of surface identifiers
If negative, the surface is removed.
(Integer)
  1. All nodes must belong to a shell element, a brick element or a triangular shell element.
  2. A surface cannot be defined using Madymo surfaces.
  3. A surface cannot be defined by associating a hyper-ellipsoid and another type of surface.
  4. Same option as /SURF/SURF, except in case of negative ID is used.
    /SURF/DSURF/3
    Title
    1 -2
    Surface 3 = Surface 1 - Surface 2 (Surface 2 is removed)
