CONROD
Bulk Data Entry Defines a rod element without reference to a property entry.
CONROD | EID | G1 | G2 | MID | A | J | C | NSM |
CONROD | 2 | 16 | 17 | 4 | 269 |
EID | Unique element
identification number. (Integer > 0) |
G1,G2 | Grid point identification
numbers of connection points. (Integer > 0; G1 ≠ G2) |
MID | Material identification
number. 1 (Integer > 0) |
A | Area of the
rod. (Real) |
J | Torsional
constant. (Real) |
C | Coefficient for torsional
stress determination. (Real) |
NSM | Nonstructural mass per
unit length. (Real) |
- For structural problems, MID may reference only a MAT1 material entry.
- In case of plasticity problems, MATS1 can be referenced with the same ID as MAT1 in small displacement and large displacement nonlinear analysis. The plasticity behavior is considered only in the axial direction, and the torsional behavior remains elastic.
- For heat transfer problems,
MID may reference only a MAT4 material entry.
Figure 1. CONROD Element Forces and Moments
- This card is represented as a rod element in HyperMesh.
