CPYRA
Bulk Data Entry Defines the connections of the PYRA solid element.
CPYRA | EID | PID | G1 | G2 | G3 | G4 | G5 | G6 | |
G7 | G8 | G9 | G10 | G11 | G | G13 | |||
CORDM | CID |
CPYRA | 71 | 4 | 3 | 4 | 5 | 6 | 7 |
EID | Unique element
PID | A PSOLID property entry
identification number. Default = EID (Integer > 0) |
G# | Grid point identification
numbers of connection points. Default = blank (Integer ≥ 0 or blank) |
CORDM | Flag indicating that the following field references the material coordinate system. | |
CID | Material coordinate system
identification number. Default = 0 (Integer ≥ -1) |
- Grid points
G1,…,G4 must be given in consecutive order
about the quadrilateral face.
The edge points, G6 through G13, are optional. If any of the edge points are present, they all must be used. The continuation must not be present for the 5-noded version of this element.
It is recommended that the edge points be placed near the middle of the edge.
Figure 1. CPYRA Definition - Stresses are output in the material coordinate system. The material coordinate system is defined on the referenced PSOLID entry. It may be defined as the basic coordinate system (CORDM = 0), a defined system (CORDM = Integer > 0), or the element coordinate system (CORDM = -1).
- The element coordinate system for the
CPYRA element is defined as follows:Three intermediate vectors R, S, and T are chosen by the following rules:
- R
- Joins the midpoints of the edges from G1 to G4 and G2 to G3.
- S
- Joins the midpoints of the edges from G1 to G2 and G3 to G4.
- T
- Joins the intersection of R and S to G5.
Figure 2. CPYRA Element Coordinate SystemThe origin of the element coordinate system is located at the intersection of the vectors R and S.
The element z-axis corresponds to the T vector.
The element y-axis is the cross product of the T and R vectors.
The element x-axis is the cross product of the element y-axis and the element z-axis.
- For more information, refer to Three-dimensional Solid Elements in the User Guide.
- This card is represented as a pyra5 or pyra13 element in HyperMesh.
