DVPREL2
Bulk Data Entry Relates a design variable to an analysis model property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
DVPREL2 | ID | TYPE | PID | PNAME/ FID |
EQID | ||||
DESVAR | DVID1 | DVID2 | DVID3 | DVID4 | DVID5 | DVID6 | DVID7 | ||
DVID8 | DVID9 | etc. | |||||||
DTABLE | LABL1 | LABL2 | LABL3 | LABL4 | LABL5 | LABL6 | LABL7 | ||
LABL8 | etc. |
Example 1
DVPREL2 | 201 | PBAR | 1 | 4 | 101 | ||||
DESVAR | 5 | 6 | |||||||
DVPREL2 | 203 | PBAR | 1 | 5 | 102 | ||||
DVPREL2 | 204 | PBAR | 1 | 6 | 103 | ||||
DESVAR | 5 | 6 |
Example 2
DVPREL2 | 201 | PBAR | 1 | A | 101 | ||||
DVPREL2 | 203 | PBAR | 1 | I1 | 102 | ||||
DVPREL2 | 204 | PBAR | 1 | I2 | 103 | ||||
DESVAR | 5 | 6 |
Associated Cards
DESVAR | 5 | W | 6.0 | 1.0 | 10.0 | ||||
DESVAR | 6 | D | 5.0 | 1.0 | 20.0 | ||||
DEQATN | 101 | AREA(W,D) = W*D | |||||||
DEQATN | 102 | I1(W,D) = (W*D**3)/12 | |||||||
DEQATN | 103 | I2(W,D) = (D*W**3)/12 | |||||||
PBAR | 1 | 222 | 0.1 | 19e-4 | 1e-3 |
ID | Relationship identification number. ID must be
unique with respect to other
DVPREL1 cards. No default (Integer > 0) |
TYPE | Property type to be related (see DVPREL - Types). No default (Character) |
PID | Property identification number. When PTYPE is PCOMPG, G# may be used where, # is the GPLYID. When PTYPE is PCOMPP, P# may be used where, # is the PLY ID. 5 No default (Integer > 0) |
PNAME/FID | Property name, such as "A" or "T" (as in the documentation of the property cards),
or field number in property card. For the PSHELL property 12I/T3,
only the filed number (6) is allowed. For PBARL and
PBEAML only property names are allowed, as different sections
use different fields. No default (Character or Integer > 0) |
EQID | Equation ID of DEQATN
data. No default (Integer > 0) |
DESVAR | Indicates DESVAR ID numbers follow. | |
DVIDi | DESVAR ID. No default (Integer > 0) |
DTABLE | Indicates DTABLE labels follow. | |
LABLi | Constant label on DTABLE
card. No default (Character) |
- TYPE cannot be PSOLID.
- When TYPE is PBARL or PBEAML, users should pay close attention to the variable ranges to avoid invalid dimensions.
- PBEAML definitions with more than one section definition may not be referenced by a DVPREL1.
- Properties of PBARL/PBEAML have to be controlled through DIMs (cannot be controlled directly), with the exception of NSM.
- When TYPE is
PCOMPG, either global plies or property specific plies may be
selected.
To select property specific plies, the format is similar to that used for other property types where the property identification number of the PCOMPG is entered in the PID field and then either PNAME or FID is used to identify the value to be related. In this scenario, only the property with an ID given in the PID field is affected.
To select global plies, G# is entered in the PID field where # is the GPLYID of a global ply. In this instance, FID is not applicable so T or THETA is used in the PNAME field to relate either the thickness or orientation, respectively. In this scenario, all plies that use the given GPLYID are affected.
When TYPE is PCOMPP, P# is entered in the PID field/ Where, # is the ID of a PLY entity. In this instance, FID is not applicable so T or THETA is used in the PNAME field to relate either the thickness or orientation, respectively.
- In the PCOMP property, the damping coefficient, GE is a designable value and can be referenced in the PNAME/FID field.
- This card is represented as an optimization design variable in HyperMesh.
