PBAR
Bulk Data Entry Defines the properties of a simple beam (bar), which is used to create bar elements via the CBAR entry.
PBAR | PID | MID | A | I1 | I2 | J | NSM | ||
C | C | D1 | D2 | E1 | E2 | F1 | F2 | ||
K1 | K2 | I12 |
PBAR | 39 | 6 | 2.9 | 8.4 | 5.97 | 1.1 | |||
2.0 | 4.0 |
PID | Unique simple beam
property identification.
No default (Integer > 0 or <String>) |
MID | Material identification.
1
2
A | Area of bar
cross-section. No default (Real ≥ 0.0) |
I1 | Area moment inertia in
plane 1 about the neutral axis. No default (Real ≥ 0.0) |
I2 | Area moment inertia in
plane 2 about the neutral axis. No default (Real ≥ 0.0) |
I12 | Area product of
inertia. Default = 0.0 (Real) (I1 > 0,. I2 > 0., I1 * I2 > I122) |
J | Torsional
constant. Default = 0.0 (Real > 0.0) |
NSM | Nonstructural mass per
unit length. Default = 0.0 (Real) |
K1, K2 | Area factor for
shear. Default = 0.0 (Real) |
Ci, Di, Ei, Fi | Stress recovery
coefficients. Default = 0.0 (Real) |
- For structural problems, MID may reference only a MAT1 material entry. For heat transfer problems, MID may reference only a MAT4 material entry.
- String based labels allow for easier visual identification of properties, including when being referenced by other cards. (For example, the PID field of elements). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- The transverse shear stiffness in planes 1 and 2 are (K1)AG and (K2)AG, respectively. The default values for K1 and K2 are infinite; in other words, the transverse shear flexibilities are set equal to zero. K1 and K2 are ignored if I12 ≠ 0. If a value of 0.0 is used for K1 and K2, the transverse shear flexibilities are set to 0.0 (K1 and K2 are interpreted as infinite).
- The stress recovery coefficients C and C, and so on, are the y and z coordinates in the BAR element coordinate system
of a point at which stresses are computed. Stresses are computed at both ends of
the BAR.
Figure 1. Coordinate System for Bar Element (PBAR) - The moments of inertia are defined
as:
(1) (2) - This card is represented as a property in HyperMesh.
