The Weld Evaluation
There are six types of welds that are supported by HL-WC.
Weld Type | Illustration |
T - Welds | ![]() |
L - Welds | ![]() |
Butt Welds | ![]() |
Overlap Welds | ![]()
Cross (X) Welds | ![]() |
Multiple (M) Welds | ![]() |
Some Considerations for Weld Evaluations
- For T and L welds, the coordinate system of the 1D beam element is oriented in such a way that the Y axis of the coordinate system points to Location 1 of the weld and the Z axis of the coordinate system points to Location 3 of the weld element.
- For all the supported weld types, the X axis of the 1D beam coordinate system is oriented along with weld direction.
- You need to check and modify the classification parameters for all the welds to be evaluated.
