abfDefaultPrecision()
Indicates the default precision of the values in the currently open ABF file.
void abfDefaultPrecision(int prec);
prec
The precision in bytes.
abfDefaultPrecision(4); /* use floats instead of doubles */
ABF supports one-, two-, four-, or eight-byte integers and four- or eight-byte real numbers.
The default is eight-byte "doubles."
