hwi GetActiveWindowHandle
HyperWorks Tcl Modify
View new features for HyperWorks Desktop 2020.1.
Ends automatic handle tracking and releases any handles acquired during handle tracking.
Gets a handle to the current session.
Gets a list of all active handles.
Begins automatic handle tracking.
ON THIS PAGE
ON THIS PAGE
