hwIJPGExportOptions GetQuality
Gets the quality used when exporting JPG files.
hwIJPGExportOptions_handle GetQuality
HyperWorks Tcl Query
Returns the quality used when exporting JPG files. This is a floating point value between 0 and 100 (exclusive). A large quality means better image fidelity but larger image size.
This parameter is used when exporting JPG files from any client during HTML export.
To determine the current quality setting used when exporting JPG files:
mySessionName GetJPGExportOptionsHandle myJpgOptions
myJpgOptions GetQuality
Error
If an error occurs, this command returns 0.
