hwIPPTPublish SetDestination
Sets the destination/location to publish the session.
hwIPPTPublish_handle SetDestination type
HyperWorks Tcl Modify
type
The location where you want to publish a session. The session gets published to the destined string type. If disk is given as string, then the appropriate path should be specified in the SetPathOnDisk command.
new
Session is published to a new PowerPoint file.
open
Session is published to an opened PowerPoint file.
disk
Session is published to a specified file on disk.
This sets the PowerPoint destination to new. Replace new with open or disk for other options.
PPTPublish SetDestination new
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
Query
