hwIPPTPublishOption SetGraphicsDistanceLeft
Sets the left offset of the graphics area.
hwIPPTPublishOption_handle SetGraphicsDistanceLeft p_image_left_offset
HyperWorks Tcl Modify
p_image_left_offset
The left offset of the graphics area.
To set the graphics distance from the left to 20 and change either the width or height, whichever is not the master dimension (as UpdateResolution is true by default):
Opt SetGraphicsDistanceLeft 20
To set the graphics distance from the left to 20, but not change the width or height, as the update resolution is false.
Opt SetGraphicsDistanceLeft 20 false
Error
Returns success (0) or an error code.
Keywords
HyperWorks
Tcl
Query
