hwIReportTemplate GetParameterEnabled
Returns the information whether the given parameter is enabled or not.
hwIReportTemplate GetParameterEnabled name
HyperWorks Tcl Query
This command gets the information whether the given parameter is enabled or not.
name
The name of the parameter.
hwi GetSessionHandle sess;
sess GetReportTemplateHandle rep 1;
rep GetParameterEnabled paramterName;
Error
Returns true (the parameter is enabled) or false (the parameter is not enabled).
Keywords
HyperWorks
Tcl
Report Template
Template
Query
