plt3DICursor FindLocalMax
Moves the cursor to the local maximum of one component of the plot along an axis.
plt3DICursor_handle FindLocalMax component axis direction
HyperWorks Tcl Query
component
The component (X, Y, or Z).
axis
The axis to scan (X, Y, or Z).
direction
Either "forward" or "backward."
To find the next local maximum Z value along X:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetAxisHandle mySurfaceName 1
mySurfaceName GetCursorHandle myCursorName 1
myCursorName FindLocalMax "z" "x" foreward
If no further maxima exist, the cursor is not moved.
