plt3DIParametric GetParametric
Gets the data group parametric state.
plt3DIParametric_handle GetParametric
HyperWorks Tcl Query
Returns the enabled parametric equations.
None.
View new features for HyperWorks Desktop 2020.1.
Gets a handle to a pltIVector interface for the specified curve.
Sets the data group parametric state.
ON THIS PAGE
None.
ON THIS PAGE
