plt3DIPlane SetHighlighted
Sets whether the plane is highlighted.
plt3DIPlane_handle SetHighlighted enabled
HyperWorks Tcl Modify
The appearance of a highlighted plane will change to indicate that it is active or has been picked through the GUI. To see this effect, alter the highlighted flag to cause a redraw of the client.
- enabled
- Highlighted, true or false.
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetPlaneHandle myPlaneName
myPlaneName SetHighlighted true
myClientName Draw
Success (0) or an error code.
