pltICurveComplex Cut
Applies a cut edit to the curve.
pltICurveComplex_handle Cut from_val, to_val, orientation, interpolate
HyperWorks Tcl Modify
This method only applies the edit. Call the Recalculate method on the parent plot object to update the data.
- from_val
- The minimum value of the range to be cut.
- to_val
- The maximum value of the range to be cut.
- orientation
- The orientation of the edit.
- horizontal
- vertical
- interpolate
- Indicates whether to create new data points at from_val and to_val (using linear interpolation) if they are not already there. Options include true or false.
Returns success or an error code.
