pltIEdit GetFromValue
Gets the minimum value of the edited range.
pltIEdit_handle GetFromValue
HyperWorks Tcl Query
The minimum value of the edited range.
None.
View new features for HyperWorks Desktop 2020.1.
Gets the replacement expression of the edit.
Gets the interpolation state of the edit.
Gets the name of the edit.
Gets the orientation of the edit.
Gets the maximum value of the edited range.
Gets the type of the edit.
ON THIS PAGE
None.
ON THIS PAGE
