pltIMacro SetComplexNotePositionInROP
Sets the position of the complex macro note.
pltIMacro_handle SetComplexNoteAttachPtInROP in_rop
HyperWorks Tcl Modify
This command sets the position of the complex macro note (in the real/phase plot or the imaginary/magnitude plot). This function only works if there is a complex macro with a note.
in_rop
true
If you want the complex macro to be in the real or phase plot (depending on what kind of plot it is set to).
false
If you want the complex macro to be in the imaginary or magnitude plot.
hwi GetSessionHandle sess;
sess GetClientManagerHandle pm Plot;
pm GetMacroHandle mc 1;
mc SetComplexNotePositionInROP true;
mc Apply original false;
Keywords
HyperWorks
Tcl
Complex Plot
Macro
Note
Modify
