pltIVector SetRequest
Sets the request used by the vector.
pltIVector_handle SetRequest request
HyperWorks Tcl Query
This method is only valid for file vectors.
request
The name of the request used by the vector. This will be dependent on the data file referenced by the vector. This method only changes the filename. Call the Recalculate method on the parent plot object to update the data.
Success or an error code.
