poIQueryExpressionRule SetExpression
Sets the query expression to the advanced query.
rule_handle SetExpression queryExpression
HyperView Tcl Modify
This command is used to set the expression query to the advanced query.
- queryExpression
- Accepts only the following rule types: ">= ", "<= ", or "range".
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule expression]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetExpression ">= 100"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations “current” “current”
advancedQuery_handle SetQueryRule "[rule_handle GetID]"
advancedQuery_handle SetQuery “entity.id entity.value”
advancedQuery_handle GetValueList
hwi CloseStack
This command returns HW_Error
, if an invalid string is passed to the query
expression.
