poIResultMathCtrl GetResultMathResourceFileName
Gets the file name corresponding to the index of the additional result file.
rmath_handle GetResultMathResourceFileName res_idx
HyperView Tcl Query
This command returns the file name corresponding to the index of the additional result files. Index starts with "0".
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
# Add 3 Result files (bumper, bumper foam, airbag)
set mid [client_handle AddResultMathAnalysis “Standard”, “c:/samples/bumper/d3plot”, “c:/samples/bumper/d3plot”, 0, 0, “c:/samples/bumper_foam/d3plot;c:/samples/airbag/d3plot”]
client_handle GetModelHandle model_handle $mid
# Get the resource label/filename corresponding to the 3 subcases
set res1 [model_handle GetResultMathResourceFileName 0]
set res2 [model_handle GetResultMathResourceFileName 1]
set res3 [model_handle GetResultMathResourceFileName 2]
# res3 should be invalid/empty
hwi CloseStack
None.
