pulIMacro CopyParameter
Copies the given parameter for the current macro.
pulIMacro CopyParameter index
HyperWorks Tcl Modify
This command copies the parameter with the given index.
- index
- The index of the parameter to be copied. Must be a positive integer.
hwi GetSessionHandle sess
sess GetClientManagerHandle pm plot
pm GetMacroHandle macro 1
macro AddParameter “Parameter 1”
macro CopyParameter 1
macro PasteParameter 1
Returns 3 = HW_InvalidHandle if there is an invalid macro handle.
Returns 4 if index is less than 0 or greater than the number of parameters in the current macro.
Keywords
HyperWorks
Macro
Tcl
