FE Absorb Examples
Expected behavior for NSM absorption dependent on the initial situation and the absorption options set.
Default Options During Absorption are "NSM on Property" and "if not possible on Elements"
- NSM defined on Property - the elements referencing the listed properties can
be described by complete components. This is always the case if the
properties are exclusively assigned indirectly via the components. In rare
cases this also works for direct property assignment.
- Connector can be created exclusively with components as links.
- Connector is marked as on property or on elements.
- Connector is green.
- Successful re-realization as NSM defined on Property.
cannot be described by complete components because of direct property
assignment on some elements.
- Connector can only be created as a mixture of component and element links.
- NSM defined on Elements - listed elements can be described by complete
components.
- Successful re-realization as NSM defined on Property or on Elements. (On Property only if the properties referenced by the linked components are not referenced from somewhere else, for example, not linked components.).
- NSM defined on Elements - listed elements cannot be described by complete
components.
- Successful re-realization as NSM defined on Property or on Elements. (On Property only if the properties referenced by the linked elements are not referenced from somewhere else, for example, not linked components.).
Option During Absorption "NSM on Property" and "if not possible fail connector"
- Connector can be created with exclusively components as links.
- Connector is marked as "on property or fail connector".
- NSM defined on Property - the elements referencing to the listed properties
components.
- Connector is green or red (green only if the properties referenced by the linked components are not referenced from somewhere else, for example, not linked components.).
- Re-realization as NSM defined on Property. Successful only if the properties referenced by the linked components are not referenced from somewhere else, for example, not linked components.
components.
- Connector is green or red (green only if the properties referenced by the linked elements are not referenced from somewhere else, for example, not linked components.).
- Re-realization as NSM defined on Property. Successful only if the properties referenced by the linked elements are not referenced from somewhere else, for example, not linked components.
Option During Absorption "NSM on Elements"
cases this works for direct property assignment as well.
- Connector is marked as "on Elements".
- Successful re-realization as NSM defined on Elements.
components.
components.
