Perform automatic checks on CAD models, and identify potential issues with geometry that may slow down the meshing
process using the Verification and Comparison tools.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to
be compatible with this release.
A modified Tcl based graphical user interface developed based on customer feedback for the previously supported GUI with 4-point
selection for a quick definition of the CAERO1 panel.
Flutter curves enable you to read in .f06 files that contain
flutter summary data for PK or PKNL solutions.
Restriction: Only available in the Nastran (MSC) user profile.
From the menu bar, click Aerospace > Aeroelasticity > Flutter Curves.
Upon importing data, this application creates an internal table with data and
allows you to select required point and result types to plot across any result
types. The Plot Editor is used to post the plot.
Click the Open file icon and select the
.f06 file.
Click Import to read the file.
Select the specific table data.
Select the data type on the x axis and y axis.
Click Plot to move the data to the Plot Editor.
Select the plot from the editor, and click the display checkbox to show the
plot.
You can select as many plots as needed, and select any desired plots to be
displayed from the selected plots.
Upon closing the plot user interface, all
of the plots internally created will be deleted and a new set of plots will
be created for every new session. Figure 1.
