Opening Model Files
From the File menu select Open > Model.
Or
Click the Open Model buttonon the Standard toolbar.
Note: If the Open Model button is not visible on the toolbar, click on the Open drop-down menu (the arrow next to the current icon) and select the Open Model option. -
From the Open Model dialog, locate and select the mdl file
to be loaded and click Open.
Figure 2.The model is loaded into the current MotionView window.
