Remove Objectives and Constraints
![](../../images/post_processing/optimization_wizard_mv_setup_delete.png)
- If a Response Variable is deleted, the corresponding objective and constraint (which uses the RV) will automatically be deleted.
- If a Response Variable is suppressed, the corresponding objective and constraint (which uses the RV) will automatically be greyed out and it will not be used for the study (see below).
![](../../images/post_processing/optimization_wizard_mv_setup_deactivated.png)
