When you build front or rear vehicle models using the Model Assembly Wizard you can add analyses using the Analysis Task
Wizard that include output requests for Suspension Design Factors (SDFs) which are useful for assessing a suspension’s
kinematic and compliance characteristics.
Analysis Tasks create systems and forces or motions which load or move the suspension or full vehicle. Tasks can be modified
and saved for reuse in other models. Many common suspension and vehicle tasks are included as part of the library. You
can also create and run tasks.
Analysis tasks create systems and forces or motions which load or move the suspension or full vehicle. Tasks can be modified
A quasi-static simulation during which the left and right suspension is exercised from jounce to rebound and various suspension
parameters are calculated.
The coil spring adjuster can be used to adjust a coil spring rate and preload at a suspension position for a particular
wheel load and suspension rate.
Static Ride Analysis
A quasi-static simulation during which the left and right suspension is exercised from jounce to rebound and various suspension parameters are calculated.
Static Roll Analysis
A quasi-static simulation during which a rolling movement is applied to the suspension and various parameters are calculated.
Coil Spring Adjuster
The coil spring adjuster can be used to adjust a coil spring rate and preload at a suspension position for a particular wheel load and suspension rate.
Static Loads Analysis
A quasi-static simulation to study the effect of various load cases applied at the wheel center and tire patch.
Tire Height Analysis
A quasi-static simulation during which the suspension is exercised from jounce to rebound and the corresponding spring and axle loads are reported.
