Saving and Running the Current Model
Select this option to save and run the current model.
- If User Control is selected as the simulation type, a new tab becomes available allowing you to define a user subroutine.
- Select Scripted simulation if a simulation script exists in the model in the form of Template or CommandSets. Checking this option prevents MotionView from exporting the Simulate command (Simulation type, End time, and Print Interval) from the Run Solver panel to the solver deck.
- Check Export MDL snapshot to save a copy of the MDL file in the current state at which the model is being submitted to the solver.
- Check Export MDL animation file to write an .maf file which can be loaded as a model in HyperView to view results with .mrf.
- MotionSolve lists information in a log file which has a .log extension appended to the solver file base name. Click View Log to view the run log in a text window.
- Click Animate to animate the results in a HyperView window after the solution is completed.
- Click Plot to plot the results in a HyperGraph window after the solution is completed.
