Processing math: 100%
ACCEL
Bulk Data Entry Defines acceleration loads to all grids in the model. These loads can either be constant or vary in a particular direction over sections of the model.
ACCEL SID CID N N N DIR
  LOC1 VAL1 LOC2 VAL2 etc.
ACCEL 12 0 1.0 2.0 .10 Y
  0.0 4.0 200.0 5.0
SID Acceleration load set identification number.
(Integer > 0)
CID Coordinate system identification number.
= 0 (Default)
References the basic coordinate system
(Integer ≥ 0, or blank)
N,N,N Acceleration load vector components in the coordinate system CID.
Default = blank (Real, if non-zero loading is required, then a minimum of one Ni should be non-zero)
DIR Component direction of the acceleration load variation.
Default = blank (Character; one of X, Y, or Z)
LOCi Location of the scale factor to the applied acceleration load along direction DIR in the coordinate system CID.
Default = blank (Real)
VALi Load scale factor at the location LOCi
  1. The acceleration load applied to all grid points in the model is given by:(1)
    a=VAL*N
    Where,
    a
    Acceleration load.
    N
    Vector with components N, N, and N.
    VAL
    Directional scale factor.
    It is not mandatory to define the directional scale factor. No scale factor is defined if you do not define DIR, VALi, and LOCi. In such cases, only N, N, and N can be defined to apply a constant acceleration load throughout the model.
    If DIR, VALi, and LOCi are defined, then the scale factor VAL for each grid in the model is automatically by linear interpolation between VALi for the DIR component of the corresponding LOCi between which the required grid point lies. If the GRID point's DIR coordinate in the coordinate system CID is outside the range specified by LOCi, the corresponding VAL is determined either from VAL1 or VALn (Figure 1). A minimum of two pairs of (LOCi and VALi) should be specified, if such directional scaling is required.
    Figure 1. Acceleration Load Factor (VAL) vs Location Along DIR (LOC)
  2. The acceleration loads specified in the ACCEL entry can be combined with other loads, such as FORCE, MOMENT, GRAV, ACCEL1, and ACCEL2, through the LOAD Subcase Information Entry. The SID on the ACCEL entry should be unique with regard to any other load entry.
  3. The acceleration load does not include effects, due to mass on SPOINTs.
  4. This card is represented as a force load in HyperMesh.
