CONTPRM
Bulk Data Entry Defines the default properties of all contacts and sets parameters that affect all contacts.
CONTPRM | PARAM1 | VALUE1 | PARAM2 | VALUE2 | PARAM3 | VALUE3 | PARAM4 | VALUE4 | |
PARAM5 | VALUE5 |
CONTPRM | GPAD | 0.5 | STIFF | AUTO | MU1 | 0.3 |
PARAMi | Parameter name. | |
VALi | Parameter value. |
Parameters for Small Displacement Nonlinear Analysis
Name | Values | SI Unit Example |
GPAD | "Padding" of master or
slave objects to account for additional layers, such as shell
thickness, and so on. This value is subtracted from contact gap
opening as calculated from location of nodes. 1
(Real) |
STIFF | Relative stiffness of the
contact interface. 2 Positive value (STIFF = Real > 0.0) is directly specified stiffness. Negative value (STIFF = Real < 0.0) defines a stiffness scaling factor. The stiffness scaling factor is equal to |Real < 0.0|. The scaling is applied to the automatic stiffness value (the stiffness value when STIFF = AUTO). Default = AUTO (AUTO, SOFT, HARD, Real > 0.0, or Real < 0.0) |
MU1 | Coefficient of static
friction (
μ
s) 3
4 Default = 0.0 (Real ≥ 0.0 or STICK or FREEZE) |
MU2 | Coefficient of kinetic
friction (
μ
k). Default = MU1 (0.0 < Real < MU1) |
PREPRT | Prints initial contact
conditions (except for MPC-based TIE) into an
ASCII data file. The file name is:
<filename>.cpr. For more information,
refer to .cpr file.
CONTGAP | Creates a Bulk Data file
that contains internally created node-to-surface contact elements
represented as CGAPG elements. The file name is:
filename_root.contgap.fem. 5
CONTGRID | Creates a Bulk Data file
that contains SET's of grids involved with
surface-to-surface contact elements. The file name is:
filename.root.contgrid.fem.
CONTOUT | Depending on the type of
contact discretization, the following file(s) are created. S2S discretization: Creates a Bulk Data file that contains internally generated Surface-to-Surface Contact elements represented as PLOTEL and RBE3 elements for visualization. The file name is: <filename>.contout.fem. N2N discretization: Creates a Bulk Data file that contains
internally generated Node-to-Node Contact elements represented
as RBEAM
JOINTG elements for visualization. The file
name is: <filename>.n2s.fem.
CONTMPC | Outputs internally created
MPC's used to generate TIE
contact. The MPC's are output to:
<filename>_contmpc.fem.
NONTIED | Controls the output of
grids which are not tied in the TIE or
CONTACT
(TYPE=FREEZE) interfaces.
TIE | Indicates the type of
contact formulation that is used when the TIE Bulk Data Entry is present in
the model.
CORIENT | Indicates whether the
master orientation field MORIENT on the
CONTACT card applies to all surfaces or if it
excludes solid elements.
SFPRPEN | Indicates whether initial
pre-penetrations are recognized and resolved in self-contact areas.
(This only affects self-contact areas, wherein Master and Slave
belong to the same set or surface).
FRICESL | Frictional elastic slip -
distance of sliding up to which the frictional transverse force
increases linearly with slip distance. Specified in physical
distance units (similar to U0 and
GPAD). Refer to Friction in the User Guide.
ADJGRID | Creates a Bulk Data file
that contains contact grid SET's. The coordinates
of these grids are adjusted (ADJUST), and a bulk data file that
contains new coordinates of these contact grids after adjustment is
also created. The file names are:
filename_root.adjgset.fem and
filename_root.adjgcrd.fem. For N2N
contact, the file names are:
filename_root.n2n.adjgset.fem and
filename_root.n2n.adjgcrd.fem.
Additionally, the maximum adjusted distance is available in the
.out file.
DISCRET | Contact discretization
approach for all the
CONTACT/TIE entries which
do not have an explicit DISCRET specification.
LSLDCLR | Indicates whether
CLEARANCE is allowed for finite/continuous
sliding
(TRACK=FINITE/CONSLI)
contact with large displacement analysis.
Parameters for Explicit Dynamic Analysis (ANALYSIS = EXPDYN)
Interface stiffness scale
factor. Default = 1.0 in implicit analysis Default = 0.1 in explicit analysis (Real ≥ 0) |
FRIC | Coulomb
friction. Default = 0.0 (Real ≥ 0) |
GAP | Gap for impact activation.
7
8 (Real ≥ 0) |
I | Node and segment deletion flag.
(Integer) |
Handling of initial
penetrations flag. 10 Default as defined by
CONTPRM (Integer = 0, … , 5)
Valid in explicit analysis: 0, 1, 2, 3 and 5. Valid in implicit analysis: 0, 3 and 4. Invalid entries are ignored. |
CONTACT card applies to all surfaces, or if
it excludes solid elements.
I | Friction formulation flag.
12
In implicit computation, only IFRIC = COUL is implemented. (Character) |
I | Friction filtering flag.
11
(Character) |
FFAC | Filtering coefficient
(Only with IFILT ≠ NO). (0.0 < Real < 1.0) |
I | Friction penalty
formulation type. 13
14
(Character) |
C, C, C, C, C, C | Friction law
coefficients. (Real > 0) |
Flag to ignore slave nodes
if no master segment is found for TIE contact.
15
(Integer) |
MTET10 | Flag for second order
CTETRA as contact master surface.
(Integer) |
I | Symmetric contact flag.
If SSID defines a grid set, the contact is always a master-slave contact. (Character) |
I | Flag for edge generation
from slave and master surfaces.
(Character) |
FANG | Feature angle for edge
generation in degrees (Only with I = FEAT). Default = 91.0 (Real ≥ 0) |
I | Gap definition flag.
(Character) |
I | Stiffness definition flag.
6
(Integer) |
STIF1 | Interface stiffness (Only
with I = 1). Default = 0.0 (Real ≥ 0) |
STMIN | Minimum interface
stiffness (Only with I > 1). (Real ≥ 0) |
STMAX | Maximum interface
stiffness (Only with I > 1). Default = 1030 (Real ≥ 0) |
IBC | Flag for deactivation of
boundary conditions at impact. (Character = X, Y, Z, XY, XZ, YZ, or XYZ) |
VISS | Critical damping
coefficient on interface stiffness. Default = 0.05 (Real ≥ 0) |
VIS | Critical damping
coefficient on interface friction. Default = 1.0 (Real ≥ 0) |
Sorting factor. Default = 0.20 (Real ≥ 0) |
- The initial gap opening is calculated automatically based on the relative location of slave and master nodes (in the original, undeformed mesh). To account for additional material layers covering master or slave objects (such as half of shell thickness), the GPAD entry can be used. GPAD option THICK automatically accounts for shell thickness on both sides of the contact interface (this also includes the effects of shell element offset ZOFFS or composite offset Z0).
- Option STIFF=AUTO determines the value of normal stiffness for each contact element using the stiffness of surrounding elements. Additional options SOFT and HARD create respectively softer or harder penalties. SOFT can be used in cases of convergence difficulties and HARD can be used if undesirable penetration is detected in the solution. A negative value for STIFF indicates that a stiffness scaling factor equal to |Real < 0.0| is defined. This scaling is applied on the stiffness value via STIFF = AUTO.
- MU1=STICK is interpreted in OptiStruct as an enforced stick condition - such contact interfaces will not enter the sliding phase. Of course, the enforced stick only applies to contacts that are closed.
- MU1=FREEZE enforces zero relative displacements on the contact surface - the contact gap opening remains fixed at the original value and the sliding distance is zero. The FREEZE condition applies to all slave nodes, no matter whether their initial gap is open or closed.
- The file
filename_root.contgap.fem, produced using the
CONTGAP parameter, can be imported into HyperMesh in order to visualize internally created
node-to-surface contact elements (now converted to GAPG
entities).Note: During optimization, this file shows node-to-surface contact elements for the latest optimization iteration. In order to correctly visualize this configuration in HyperMesh for shape optimization problems, the FEA mesh shape needs to be updated by applying "Shape change" results.
Furthermore, if GAPPRM,HMGAPST,YES is activated together with CONTPRM,CONTGAP,YES, then the gap status command file, filename_root.HM.gapstat.cmf, will also include the open/closed status of these additional GAPG's that represent node-to-surface contact elements. For correct visualization of their status in HyperMesh, file filename_root.contgap.fem needs to be imported before running the gap status command file.
- If I ≠ 1, the interface stiffness K is computed from the master segment stiffness
Km and/or the slave segment stiffness Ks.
The master stiffness is computed from Km=STFAC⋅B⋅S⋅SV for solids, Km=0.5⋅STFAC⋅E⋅t for shells as well as when the master segment is shared by a shell and a solid.
The slave stiffness is an equivalent nodal stiffness computed as for solids:(1) For Shells:Ks=STFAC⋅B⋅V−3(2) Ks=0.5⋅STFAC⋅E⋅tWhere,- B
- Bulk modulus
- S
- Segment area
- E
- Modulus of elasticity
- t
- Shell thickness
- V
- Volume of a solid
There is no limitation to the value of stiffness factor (but a value greater than 1.0 can reduce the initial time step).
I = 0, the interface stiffness K=Km
I > 1, the interface stiffness is K=max(STMIN,min(STMAX,K1)) with:- I = 2, K1=0.5⋅(Km+Ks)
- I = 3, K1=max(Km,Ks)
- I = 4, K1=min(Km,Ks)
- I = 5, K1=Km⋅Ks/(Km+Ks)
- In an implicit analysis, the contact
stiffness plays a very important role in convergence. I = 4 (which takes the minimum of master and slave stiffness's for contact) is
recommended. This is because the penalty contact force will be balanced with the
internal force of the deformable impacted part, which means the stiffness near
the effective stiffness one will converge easier than a higher one.
For small initial gaps in implicit analysis, the convergence will be more stable if a GAP larger than the initial gap is defined.
In implicit analysis, sometimes a stiffness with scaling factor reduction (for example: = 0.01) or reduction in impacted thickness (if rigid one) might reduce unbalanced forces and improve convergence, particularly in shell structures under bending where the effective stiffness is much lower than membrane stiffness; but it should be noted that too low of a value could also lead to divergence.
- The default for the constant gap (I = CONST) is the minimum of:
- t
- Average thickness of the master shell elements
- l/10, l
- Average side length of the master solid elements
- lmin/2, lmin
- Smallest side length of all master segments (shell or solid)
- The variable gap (I = VAR) is computed as gs + gm with:
- gm - master element gap with
- gm = t/2, t: thickness of the master element for shell elements.
- gm = 0 for solid elements.
- gs - slave node gap:
- gs = 0 if the slave node is not connected to any element or is only connected to solid or spring elements.
- gs = t/2, t - largest thickness of the shell elements connected to the slave node.
- gs = 1/2√S for truss and beam elements, with S being the cross-section of the element.
If the slave node is connected to multiple shells and/or beams or trusses, the largest computed slave gap is used.
The variable gap is always at least equal to GAPMIN.
- = 3 or 4 are only recommended for small
initial penetrations and should be used with caution because:
- the coordinate change is irreversible
- it may create other initial penetrations if several surface layers are defined in the interfaces
- it may create initial energy if the node belongs to a spring element
= 5 works as:Figure 1.
- IFILT defines the
method for computing the friction filtering coefficient. If
IFILT ≠ NO, the tangential friction
forces are smoothed using a filter:
(3) FT=α⋅F'T+(1−α)⋅F'T−1Where,- FT
- Tangential force
- F'T
- Tangential force at time t
- F'T−1
- Tangential force at time t−1
- α
- Filtering coefficient
- IFILT = SIMP
- α = FFAC
- IFILT = PER
- α=2πdt/FFAC , where dt/T = FFAC, T is the filtering period
- IFILT = CUTF
- α=2π⋅FFAC⋅dt , where FFAC is the cutting frequency
- I defines the friction model.
I = COUL - Coulomb friction with FT≤μ⋅FN with μ=FRIC
If I is not COUL, the friction coefficient is set by a function (μ=μ(p,V)) ,
Where,- p
- Pressure of the normal force on the master segment
- V
- Tangential velocity of the slave node
The following formulations are available:
I = GEN - Generalized viscous friction law(4) μ=Fric+C1⋅p+C2⋅V+C3⋅p⋅V+C4⋅p2+C5⋅V2I = DARM - Darmstad law(5) μ=C1⋅e(C2V)⋅p2+C3⋅e(C4V)⋅p+C5⋅e(C6V)I = REN - Renard law(6) μ=C1+(C3−C1)⋅VC5⋅(2−VC5)ifV∈[0,C5](7) μ=C3−((C3−C4)⋅(V−C5C6−C5)2⋅(3−2−V−C5C6−C5))ifV∈[C5,C6](8) μ=C2−11C2−C4+(V−C6)2if V≥C6where,
C1=C1=μS,C2=C2=μdC3=C3=μmax,C4=C4=μminC5=C5=Vcr1,C6=C6=Vcr2
- The first critical velocity Vcr1 must be different to 0 (C ≠ 0). It also must be lower than the second critical velocity Vcr2 (C < C).
- The static friction coefficient C and the dynamic friction coefficient C must be lower than the maximum friction C (C ≤ C) and C ≤ C).
- The minimum friction coefficient C, must be lower than the static friction coefficient C and the dynamic friction coefficient C (C ≤ C and C ≤ C).
- I selects two types of contact friction penalty formulation.The viscous (total) formulation (I = VISC) computes an adhesive force as:
(9) Fadh=VISF⋅Sqrt(2Km)⋅VTFT=min(μFN,Fadh)The stiffness (incremental) formulation (I = STIFF) computes an adhesive force as:(10) Fadh=FTold+ΔFT(11) ΔFT=K⋅VT⋅dt(12) FTnew=min(μFN,Fadh) - For nonlinear implicit contact with friction, the stiffness formulation (I = STIFF) is recommended.
- If = 1 or 2, the slave nodes without a master
segment found during the searching are deleted from the interface.
If = 1 and SRCHDIS is blank, the default value of the distance for searching closest master segment is the average size of the master segments.
If = 2 and SRCHDIS is blank, the distance for searching closest master segment for each slave node is computed as:
d1=0.6⋅(Ts+Tm)
d2=0.05⋅Tmd
SRCHDIS=max(d1, d2)
Where,- Ts
- Thickness of the element connected to the slave node, for solids Ts = 0.0
- Tm
- Thickness of master segment, for solids Tm = Element volume / Segment area
- Tmd
- Master segment diagonal
- This card is represented as a control card in HyperMesh.
