MATS1
Bulk Data Entry Specifies stress-dependent and temperature-dependent material properties for use in applications involving nonlinear materials.
This entry is used if a MAT1 entry is specified with the same MID in a nonlinear subcase.
MATS1 | MID | TID | TYPE | H | YF | HR | LIMIT1 | ||
TYPSTRN | TSC | ||||||||
JHCOOK | A | B | N | C | RSTRT |
MATS1 | 17 | 28 | PLASTIC | 0.0 | 1 | 1 | 2.+4 |
MID | Identification entity of a MAT1 entry.
No default (Integer > 0 or <String>) |
TID | Identification number of a TABLES1, TABLEST, TABLEG or
TABLEMD entry. If H is given, this
field must be blank. 4
(Integer ≥ 0 or blank) |
TYPE | Material nonlinearity type.
H | Work
hardening slope (slope of stress versus plastic strain) in units of stress. For
elastic-perfectly plastic cases, H = 0.0. For more than a single
slope in the plastic range, the stress-strain data must be supplied on a
TABLES1 or TABLEG entry referenced by
TID, and this field must be blank. 3
(Real) |
YF | Yield function criterion, selected by the following value. 11
(Integer) |
HR | Hardening Rule, selected by the following value (Integer).
Adjustable Mixed Hardening is selected by choosing (Real) value for
HR:
(1, 2, 3, 4, 5, or 0.0 < Real < 1.0) |
LIMIT1 | Initial yield point. The LIMIT1 field can be blank, if the initial yield point value is defined via a referenced TABLES1 or TABLEG entries on the TID field. OptiStruct will error out if LIMIT1 is blank and TID does not reference a TABLES1 or TABLEG entry. (Real > 0 or blank) |
TYPSTRN | Specifies the type of strain used on the x-axis of the table pointed to by
TID. The strain type is selected by one of the following
values. 6
(Integer) |
TSC | Tensile stress cutoff. A nonzero,
positive value is recommended for realistic behavior. 6 Default = 0.0 (Real ≥ 0) |
JHCOOK | Flag that identifies that the
Johnson-Cook hardening method parameters are to follow. For Johnson-Cook hardening,
HR=4. (Integer) |
A | Material yield stress. No default (Real) |
B | Coefficinets to the plastic
strain. Default = 0.0 (Real) |
N | Exponent to the plastic
strain. Default = 1.0 (Real) |
C | Coefficient to the strain
rate. Default = 0.0 (Real) |
RSTRT | Reference strain rate. Default = 1.0 (Real) |
- String based labels allow for easier visual identification of materials, including when being referenced by other cards. (example, the MID field of properties). For more details, refer to String Label Based Input File in the Bulk Data Input File.
- For nonlinear elastic material, the stress-strain data given in the TABLES1 or TABLEG entry will be used to determine the stress for a given value of strain. The values H, YF, HR, and LIMIT1 will not be used in this case. Nonlinear elastic material is only available in EXPDYN subcases.
- For elastoplastic materials,
the elastic stress-strain matrix is computed from a MAT1 entry, and the
isotropic plasticity theory is used to perform the plastic analysis. In this case, either
the table identification TID or the work hardening slope
H
may be specified, but not both. If the
TID is omitted, the work hardening slope
H
must be specified, unless the material is perfectly plastic.
The plasticity modulus (
H
) is related to the tangential modulus (
ET
) by:
(1) H=ET1−ETEWhere, E is the elastic modulus and ET=dY/dε is the slope of the uniaxial stress-strain curve in the plastic region.
Figure 1. - If TID is
given, TABLES1 or TABLEG entries
(Xi,Yi) of stress-strain data
ε
x,Yx) must conform to the
following rules:
If TYPE=PLASTIC, the curve must be defined in the first quadrant. The data points must be in ascending order. If the table is defined in terms of total strain (TYPSTRN=0), the first point must be at the origin (X1=0, Y1=0) and the second point (X2, Y2) must be at the initial yield point (Y1) specified on the MATS1 entry. The slope of the line joining the origin to the yield stress must be equal to the value of E. If the table is defined in terms of plastic strain (TYPSTRN=1), the first point (X1, Y1), corresponding to yield point (Y1), must be at X1=0. TID may reference a TABLEST entry. In this case, the above rules apply to all TABLES1 tables pointed to by TABLEST.
If TYPE=NLELAST, the full stress-strain curve may be defined in the first and third quadrants to accommodate different uniaxial compression data. If the curve is defined only in the first quadrant, then the curve must start at the origin (X1=0.0, Y1=0.0).
For analysis where small deformations are assumed, there should be little or no difference between the true stress-strain curve and the engineering stress-strain curve, so either of them may be used in the TABLES1 definition. For analyses where small deformations are not assumed, the true stress-strain curve should be used.
If the deformations go past the values defined in the table, the curve is extrapolated linearly.
- Kinematic hardening and Mixed hardening are supported only for solids.
- The conversion of the relation
stress vs. total strain (TYPSTRN=0) into stress vs.
plastic strain (TYPSTRN=1) is illustrated below. This
is clearly different than simply shifting the entire table along the epsilon-axis.
Figure 2. - The temperature-dependence of the MATS1 material is defined by referencing a TABLEST entry via the TID field.
- Large strain elasto-plasticity can be activated using MATS1 (TYPE=PLASTIC) in conjunction with PARAM, LGDISP,1.
- MATS1 is not supported in conjunction with second order shell elements (CTRIA6 and CQUAD8).
- MATS1 is supported for
CROD, CONROD, CBAR and
CBEAM elements in the axial translational direction only. The
behaviors in other directions remain elastic.
The torsional deformation of CROD/CONROD elements or the shear, bending and torsional deformations of CBAR/CBEAM elements remain elastic.
- If Johnson-Cook is selected
(HR=4), use the following
formulations:
(2) σ=(a+bεnp)(1+cln(˙ε˙ε0))(3) ˉσ=(A+B(ˉεpl)n)(1+Cln(˙ˉεpl˙ε0))Johnson-Cook strain rate dependence assumes that,(4) ˉσ=σ0(ˉεpl,θ)R(˙ˉεpl)and(5) ˙ˉεpl=˙ε0exp(1C(R−1))for ˉσ≥σ0
Where,- ˉσ
- Yield stress for non-zero strain rate
- ˙ˉεpl
- Equivalent plastic strain rate
- ˙ε0 and C
- Are material parameters measured at or below the transition temperature θtransition
- σ0(ˉεpl,θ)
- Static yield stress
- R(˙ˉεpl)
- Ratio of the yield stress at nonzero strain rate to the static yield stress (so that R(˙ε0)=1.0 )
- When Crushable Foam is selected
(HR=5), only maximum principal stress as yield
criterion (YF=2) is used, and a table
TID must be given.
For rate independent table (TABLES1), first column is the volumetric strain, second column is the yield stress. The volumetric strain is defined as γ=1−VV0 .
The default for TSC (tensile stress cutoff) is zero, unless the user specifies a value. TSC is defined as a positive stress value which indicates the yield stress of crushable foam under tensile loading.
The yield stress of crushable foam under compression loading can be given by a TABLES1 table.
Where,- x
- Values in the table is the volumetric strain (all positive values indicate the volume is compressed).
- y
- Value is the compression yield stress (all positive values).
For crushable foam, in place of the equivalent plastic strain in H3D file, the integrated volumetric strain (natural logarithm of the relative volume -ln(V/V0)) is output.
- If TID refers to TABLEMD, the first variable X1 is volumetric strain if HR=5 (Crushable foam), or plastic strain/full strain if HR=1, 2, 3. For rate-dependent problems, the second variable is strain rate.
