Bulk Data Entry Defines a tabular function for: Stress-strain curve in
elasto-plastic material properties MATS1, MATX33,
MATX65, MATHF, as well as material curve in
nonlinear material properties MATX36, MATX42, and
MATX70; Material curves on the MATHE Bulk Data
Entry; or Friction table vs Pseudo time in Nonlinear analysis on the MU1
field of PCONT entry.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
TABLES1
TID
FLAT
x1
y1
x2
y2
x3
y3
x4
y4
x5
y5
etc.
etc.
etc.
etc.
etc.
etc.
(1)
(2)
(3)
(4)
(5)
(6)
(7)
(8)
(9)
(10)
TABLES1
32
-3.0
6.9
2.0
5.6
3.0
5.6
ENDT
Field
Contents
SI Unit Example
TID
Table identification
number.
No default (Integer > 0)
FLAT
Specifies the handling
method for y-values outside the specified range of x-values in the
table.
=0 (Default)
If an x-value input is outside the range of x-values
specified on the Table, the corresponding y-value look
up is performed using linear extrapolation from the two
start or two end points.
=1
specified on the Table, the corresponding y-value is
equal to the start or end points, respectively.
x#,
y#
Tabular values.
No
default (Real, or ENDT)
xi must be in either ascending or descending order,
but not both.
Discontinuities between any two points
except the two starting points or two end points. For example, in Figure 1 discontinuities
are allowed only between points x2 through x7. Also, if y is evaluated at a discontinuity, the average
value of y is used. In Figure 1, the value of y at x=x3 is y=(y3+y4)/2.
At least one continuation entry must be
specified.
Any x, y pair may be ignored by placing
SKIP in either of the two fields used for that entry.
The end of the table is indicated by the
existence of ENDT in either of the two fields following the last
entry. An error is detected if any continuations follow the entry containing the
end-of-table flag ENDT.
For
FLAT=0 (default),
TABLES1 uses the algorithm:(1)
y=yT(x)
Where,
x
Input to the table
y
Is returned
The table look-up is performed using interpolation within the
table and linear extrapolation outside the table using the two starting or
end points (Figure 1). The algorithms used for interpolation or extrapolation
is:(2)
yT(x)=xj−xxj−xiyi+x−xixj−xiyj
Where, xj and yj follow xi and yi.
For
FLAT=1, the same algorithm as
FLAT=0 is used, except that values
outside the range are not extrapolated. The corresponding start or end point
y-values are used for all y-values outside the range.
For TABLES1 referenced by elasto-plastic material
property MATS1, additional requirements apply. See the
description of MATS1 for details. Figure 1. Example of Table Extrapolation and Discontinuity
Linear extrapolation is not used for
Fourier transform methods. The function is zero outside the range of the table.
For frequency-dependent loads,
x# is measured in cycles per unit time.
Some warning or error messages are issued
if table data in input incorrectly. However, since TABLES1 can
serve different and distinct purposes, error checking is limited.
