PARAM, W4
Bulk Data Entry Converts structural damping to equivalent viscous damping for transient analysis.
Parameter | Values | Description |
W4 | <Real> Default = 0.0 |
Used in
transient analyses to convert structural damping to equivalent
viscous damping. The damping matrix [B][B] for transient analysis is assembled from: [B]=[B1]+ΓΩ3[K]+1Ω4∑ΓE[KE][B]=[B1]+ΓΩ3[K]+1Ω4∑ΓE[KE] Where,
- This parameter can be specified in the Bulk Data section and/or Subcase section. If it is defined in the Subcase section, then it is subcase-specific and this value is only used for this subcase.
- PARAM, W4 is supported with direct transient, modal transient and nonlinear transient analysis types.
- The order of priority is TSTEP or RSPINR/RSPINT entry, Subcase specific PARAM, followed by Bulk Data PARAM.
