Finite Element Model Validation
FEM Accuracy Check
- The idealization and assumptions made while designing the structure.
- Checking the orientation and the cross-section of the beams that are defined in the structure and to also ensure the assignment of correct thicknesses for different components.
- Check for any overlapping nodes or elements are present in the model.
- Check to see if the mass allocated to every component matches the experimental model.
- Check that all the loading and boundary conditions are applied at the correct locations.
- Run an element quality check in HyperMesh to see if all the elements are within the acceptable criteria.
- Check the consistency of the element local direction.
FEM Validation
- Experimental test
The results from FEA can be compared to the experimental tests performed under similar loading conditions.
- Comparing with existing documents
The results from FEA can be compared to the results obtained from similar benchmarked models. The model can also be compared against established guidelines.
- Comparing with classic solution
The results from FEA can be compared with classical solutions. The model can also be compared against established guidelines.
