OS-T: 7000 Phone Drop Test Analysis
This tutorial demonstrates a phone drop test simulation using Explicit Analysis in OptiStruct when the phone is dropped on the floor with a velocity of 5425 mm/s.
- Set up the drop test model in HyperMesh
- Submit the job in OptiStruct
- View the results in HyperView
Launch HyperMesh and Set the OptiStruct User Profile
Open the Model
Apply Loads and Boundary Conditions
Create TSTEPE Load Collector
Create SPC Load Collector
This step will instruct how to create the SPC load collector to fix the floor.
Create NLOUT Load Collector
Here you will define the incremental result output parameter.
Create INVELOCITY Load Collector
This step will show you how to apply initial velocity to the phone.
Create Load Steps
Add Control Cards
Submit the Job
Review the Results
View a contour plot of stresses and displacement.
