Once you find the block you’re looking for, you can make the appropriate changes to it. Embed searches the entire diagram for the search item, regardless of your current location in the diagram.
The Find command and Find toolbar command also let you find blocks in the Blocks Browser.
Use the Find in Diagrams and Replace in Diagrams commands to expand your search to multiple diagrams.
